Old 05-09-2010, 11:13 PM   #3
batmmannn
batmmannn's Avatar
Default Starter
Actually it was a bitch but with help from this forum I was able to do it without removing anything but it was not easy. The starter is in but I let the car sit too long. I need to soak the cylinders. It barely turns over and is very stiff so I am going to put penetrating oil in the plug holes let it sit a few days and then work it loose with the crank bolt and a braking bar. The car sat for years with me planning to get to that starter but every time I tried I got so frustrated I nearly gave up. I finally have it on the road back. I think it will be OK hopefully once I get it lubed and freed a bit. It ran great when parked but had that bad starter. It actually turned a half or more revolution under starter power but I did not want to push my luck the positive terminal was getting hot. I need a spark plug wrench that will fit this thing, my standard doesn't do it. Anyone know what I need?
