Old 05-09-2010, 01:24 AM   #1
nfa_automotive
nfa_automotive's Avatar
nfa_automotive is on a distinguished road
I'd start by doing some more checking. It's possible you still have a ground problem. I would check all the ground, make sure they're are all clean and rust free.
First off safety : before doing this next step. Car needs to be in Neutral E-brake on and you Not in front of the car.
One good way to check the starter, is when it you have a no start and a good battery, is reach done to the starter, take the small connector off the starter, find a piece of wire and a female spade connector, crimp the spade onto the length of wire, put the spade on the starter terminal, take the other end of the wire and touch it to the positive terminal. The starter should engage, if it doesn't it could still be a bad ground or a bad cable from the battery to the starter.
If the starter turns over, you need to check, The starter relay, Theft Deterrent Computer, wiring, etc
A good technician should check all of those when they get a car in with a no start.
There is a lot involved.
Here is the Diagram for Starting from a 89: http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=038
And the starter is cake to replace. You just need a couple wrenches, a hr or so, and a beer or two
Let us know how it goes
1987 Supra Turbo Targa Blue 5spd 175K, 3" Exhaust from Turbo back, Lowered 1.5", 89 Steering Wheel and Climate Control, JDM Power Folding Mirrors, HKS Fan Controller, Greddy Turbo Timer, HKS EVCIII Boost Controller, Boost Gauge, Deleted Boost Gauge in Cluster for Volt, MKIV Non-Turbo wheels
1987 Supra N/A Coupe Blue Auto - Parts Car
1987 Supra Turbo Coupe Black 5spd - Bought with a spun bearing - RIP
1987 VW Jetta GTI Auto 89k
nfa_automotive is offline   Reply With Quote
