Old 05-08-2010, 06:18 AM   #1
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
Originally Posted by tak2099 View Post
Yes the coils and wires are hooked up correctly. Ok, so I wired the stock tps back up, and modified my 80mm TB to use the stock one. Now it does go past 1800 rpms, BUT it still cuts out, but now its random. At WOT it goes just fine, but under normal driving it will randomly cut out. Do you guys think maybe my tps isnt adjusted right? Or maybe if my timing was off it could cause this? Or are both of those not things that would cause a random shut off?
I would start with the timing.. Take the 7mgte cover off, and check it with the timing gun... the numbers, letters should be right stationary when you check it... hope i could help...
carlos
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
