Old 05-04-2010, 02:22 AM   #2
P&P gets quite expensive. For general head work, tanking, valve stem seals, cam lash adjustment, valves lapped, dye inspection and vacuum testing will generally run between $200 and $400... it varies a LOT depending on where you are located as well as the skills of the shop.
