Old 05-02-2010, 01:21 AM   #1
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
If you're worried that you're is not the right one then go by the part number. The name on the tag may have been changed. Additionally, the part may have been superseded any number of times so don't be surprised if you find multiple part numbers for that application.
Ok yes alot of part numbers changed. I just looked on Ebay again and a MAP sensor for a 2jz-GE says Sensor ASSY. Vacuum. Now I am starting to think this is a non turbo map sensor!
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
AlexSchuSupra is offline   Reply With Quote
