Originally Posted by cre
Oh, ok... yes, you do have one and I believe it is labeled as a "vacuum" sensor (that's how it is in all the Toyota's I've worked on with one... which isn't too many, though).
Ok just checking. All the ones from other 1jz's I have seen say turbo boost pressure so I was starting to worry. Thanks
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!  ) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P  K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
Reason: picture
