Old 04-27-2010, 07:45 PM   #2
AlexSchuSupra
AlexSchuSupra's Avatar
AlexSchuSupra is on a distinguished road
the only manifold pressure sensor on the 7M is only used for the boost gauge... unless you're using hardware to run one in place of the AFM.
I'm sorry I should have explained further. This is a 1JZ-GTE swap in my MK3
87' 7M-GE Custom fab 3" Headers, Cat-Delete, 4" High Flow Flowmaster (WTF!!!!) MAF Adapter with truck sized Spectre filter. NGK Laser Platinum Plugs. K&N Oil Filter
87' 1JZ-GTE Truck sized Spectre Air filter, Walbro 255LPH Fuel Pump, GM Fuel Pressure Regulator, Welded Rear end gears, Targa Top, 3" Intercooler kit, aluminium intercooler, Ebay boost controller, Ebay Oil-Catch can, I HAVE POWER STEERING AND A/C :P K&N 2JZ Oil filter, Catrol Syntec 10w-40 Fully synthetic oil
AlexSchuSupra is offline   Reply With Quote
