Old 04-16-2010, 05:46 PM   #2
BDRT103
BDRT103 is on a distinguished road
i have a turbo setup off a 88 supra and from what i can see the wiring harness is the same other than the fact of splicing into the igntion system for the fact of it not being the 90 model where there is more sensors. can my harness work and will it plug into the gte ecu?? And i can just run electric fans rather than the clutch fan assembly you said i should swap over right?? And i also belive that i have to change over the intake manifolds to, right??
BDRT103 is offline   Reply With Quote
