Old 04-08-2010, 09:33 PM   #2
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
I don't know if they make em anymore, but I went with fluid dynamics aluminum rad for my 1jz. Nice rad with a cooling fan kit as well. Haven't had a cooling problem ever. I'd recommend them in a heartbeat if you can find em.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
