Old 08-26-2005, 04:06 PM   #1
rnoswal
rnoswal's Avatar
Clean block $25.00
install intermediate shaft bearings $15.00
Grind crank $60.00
Bore cylinders $10.00 a hole $60.00
Con rod bearings $29.00
Main bearings $44.00
Thrust washer set $8.00
Pistons and rings , stock but oversized $36.00 ea. $218.00
Gaskets $144.00
Head gasket $13.00
Total around $700.00
Forged pistons are nice and if you are going to push it then a necessity. Sound high on some stuff but you are putting together an engine that will put out more than my N/A. I still push 6000 rpm though and I believe my engine will hold for quite a while, not with nitrous probably........but that is for another day.
Russ
