Old 01-27-2010, 07:50 PM   #11
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
Originally Posted by btwilson86 View Post
Glad it's running, just a couple thoughts though... You said that you kept adding oil? Is it because it was getting low on oil, or you thought it was low because your gauge shows no pressure? And I would try and clean off the contact on the oil pressure switch and reinstall the connector and see if that fixes it, otherwise you may want to put another oil pressure gauge in so that you can monitor it.
Also now that you've got it running, shut it off and check for codes! Wanna make sure everything is set up right and you don't have any gremlins hiding in the car...
One last thing, as much as I bet you would love to take your intake off again, you need to fix your leaky valve cover gaskets. That can only cause more problems down the road.
it was getting low on oil. i checked the dipstick. yea im going to check that oil pressure connector and see what i find. maybe that round sensor thing is bad? could it be a fuse? i really want that gauge working. and yes i definitely need to check the codes tonight. ill go over supragirls thread on how to read them.
to you have any recommendations for replacement bolts for the covers?
cvbikeguy is offline   Reply With Quote
