Thread: Dash lights
Old 01-25-2010, 05:37 AM   #4
BlueTuner
BlueTuner is on a distinguished road
go somewhere dark and turn on your lights, then go look at your tail lights, see if any aren't lighting up. FOr me it was burned out bulb. if that's it then.
open up the trunk and on the back part there should be covers right behind the tail lights, take those off and you will be able to see the tail light from the inside, there's a big white block like thing that you can remove, those hold the bulbs, remove the bulb and change it.
BlueTuner is offline   Reply With Quote
