Old 01-03-2010, 05:13 PM   #11
Androidrc
Androidrc's Avatar
Androidrc is on a distinguished road
Default mostly solved
ok well i went out and pulled my plugs. 4 out of the six were DRIPPING WET with what smelled like dirt mixed with burnt oil. it does burn some so that makes sense. i cleaned the plugs off and removed any corrosion from the wires and reinstalled everything.......RUNS GREAT. better than ever. next month (ill be away with the army for a month) im going to get after it really good and do valve cover seals, oil galley plug seals, plugs, wires, and an oil change. thanks for the help i appreciate it very much. ill let u know if anything starts up again
Androidrc is offline   Reply With Quote
