Old 01-03-2010, 01:49 PM   #11
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
Okay... I'm just the paranoid sort; It's served me well over the years.
Well, don't blame ya if you do, but I'd go over it all one more time... you're missing something. If it's back firing through the intake either the mechanical timing is off or the plug wires are installed in the wrong order.... same thing's likely if it's doing it out the back too actually.
I'd go back through the TRSM's reinstallation segment and double check everything. http://www.cygnusx1.net/Supra/Librar....aspx?S=EM&P=1
Make sure you do not over tighten the timing belt tensioner pulley, it will distort the #1 cylinder rather easily if tightened past specs.
i dunno cre. im kinda scared to see whats dead now. there was smoke in the engine and no power after last night. grrrrrrrrrrrrr
cvbikeguy is offline   Reply With Quote
