Old 01-02-2010, 09:41 PM   #2
cvbikeguy
cvbikeguy's Avatar
cvbikeguy is on a distinguished road
As long as it's all zero'd out you should land pretty close to 0* of advance with the distributor bolted in the center of it's range. Unless you're off a tooth or more on a gear there's no room in the adjustment slide to be off more than 15*... I really don't see the point in this.
so all i need to do is set everything to 0.
the cams are already lined up with the crank. but for the dist. this hash mark has to be pointing up also?
cvbikeguy is offline   Reply With Quote
