Old 12-23-2009, 05:40 PM   #1
DarkSupra2.5
DarkSupra2.5's Avatar
DarkSupra2.5 is on a distinguished road
If your turbo seals are goin bad you could be leakin oil into the exhaust. BUT, more than likely you're just running rich after having it sit for so long and the ecu is compensating for the cold. Warm it up then run it and see if it still does it. My 1j does the same thing when i let it sit for more than a week and the ecu resets itself, fuel trim goes haywire for a while.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
DarkSupra2.5 is offline   Reply With Quote
