Old 11-24-2009, 06:05 AM   #1
The component list is fairly accurate but you don't need to spend nearly that much. You don't need a M/T ECU for example, the A/T ECU will work fine. You do need the complete tranny, driveshaft, pedal set, flywheel and clutch, clutch master cylinder and hoses. Most of the parts you can get used and for pretty cheap if you pull them yourself at a salvage yard.
