Old 11-06-2009, 01:29 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by casanovacuts View Post
...As mentioned earlier I was curious how far either motor will go?...
Bone stock? With a set of cams the 2jz-gte will handle 1000hp at the crank - reliably, with race fuel. A stock 2jz-ge won't do more than about 450hp at the crank, reliably with race fuel.
...the reason I was looking at the 5 spd ea possibly more out of being anxious to get my hands on this monster anyway I could...
Not only the motor is different in the n/a - it's the entire powertrain and braking system that is weaker and less capable.
...I spoke to someone who was telling me that I should look for the 5 spd because u can ride the gears longer especially when it's turboed...
That person really has no idea. The 5spd holds less than half the power that the 6spd can. Oh, and you can re-gear the diff to get the gears to ride longer in the 6spd if you wish.
...And Rey said it was more fun than the six speed because u weren't shifting every couple of seconds. Not sure if he knew what he was talking about or not....
Not.
...So now I know to start with the TT no matter what and o saw a thread already on the necessary componnents to switch over to a manual tranny if needed. I do appreciate all of your advice. Thank you once again for your time
Anytime!
Life begins at 30psi.
