Thread: idle issue
Old 11-04-2009, 07:19 AM   #2
Okay, let's fill in a couple gaps:
Diagnostics codes:
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
Vacuum Routing (multiple references, Toyota really dropped the ball on documenting where some of them run):
http://www.cygnusx1.net/Supra/Librar...spx?F=1708&P=3
http://www.cygnusx1.net/Supra/Librar...spx?F=2211&P=2
http://www.cygnusx1.net/Supra/Librar...spx?F=2501&P=1
http://www.cygnusx1.net/Supra/Librar...spx?F=1201&P=2
http://www.cygnusx1.net/Supra/Librar...spx?F=8717&P=1
http://www.cygnusx1.net/Supra/Librar...spx?F=8408&P=1
This lists sizes: http://www.cygnusx1.net/Supra/TechTips/vacuum_hose.aspx
TPS Inspection and Calibration:
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=100
Idle Speed Controller (It's not unheard of for these to get enough detritus built up inside that the ECU is no longer able to keep a regular idle speed... cleaning is cheap and easy and may be all the fix you need):
http://www.cygnusx1.net/Supra/Librar...ction=FI&P=106
BPV (Bypass Valve/recirculating/stock setup) vs BOV (Blow Off Valve/Dump Valve/vents to atmosphere):
http://www.toyota-supra.info/forums/...rculation.html
Yes, 23280 is the fuel pressure regulator.
