Old 11-03-2009, 06:13 AM   #1
Supra_Sicc
Supra_Sicc is on a distinguished road
The 7M-GTE runs a "wasted spark" setup. Which cylinders are dropping out on you? It's quite likely the igniter or the wiring in between is the problem.
it is 1-6-3-4 are the ones dropping out. which fucking sounds like the wiring inbetween .
1989 Toyota supra. 7mgte swap
Hks ssqv blow off valve/Tokico Blue Suspension/Greddy Turbo Timer/ARP Head Studs,torqued to 85lbs/Titan Motorsports Metal Head Gasket/RPS Max Pressure Plate/Toyota Turbo Clutch Disc/1 PC Aluminum Driveshaft.
I need help with my turbo timer!!!
Supra_Sicc is offline   Reply With Quote
