Old 10-17-2009, 12:39 AM   #23
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by oregonjoe View Post
Check your plugs - if they look like coolant or have deposits its a BHG - Start with NO 6 as that is the most common - All plugs should be dry and light tan. Mine ran rough after sitting overnight and was burning coolant same on acceleration
I didn't find coolant but I did find oil...I have already replaced my No 3 valve cover with O Ring Gaskets covered in RTV, and they are not leaking so that means it's coming from inside. All 6 of my plugs were covered completely in oil
And on top of all of this my car won't even start now that I got the water pump back on and coolant back in and new plugs. I'm thinking it's possible that I might have messed up my timing since the pulleys were spinning while I was trying to get the fan off.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
