Old 10-02-2009, 03:13 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Any leak in the cooling system will result in it not easily sucking the coolant back from the reservoir. As the coolant cools down, the pressure drops which creates a vacuum in the system. This is what draws the coolant back in. If there is a leak, the cooling system could draw in air (which is easier for it to do) instead of that coolant, leaving it all in the reservoir
