Old 09-28-2009, 03:46 PM   #1
oregonjoe
oregonjoe's Avatar
Default Plugs
Plat tip plugs can not be cleaned - standard ones can but not recommended. Replace them
If oil on Both sides meaning tips - could be when they were removed they were contaminated from top oil – that’s what happened on mine. If tips are dark and burned with lots of deposits then probably leaking valve seals or bad rings
