Old 09-27-2009, 04:18 AM   #1
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by djntrance View Post
Are you saying oil on one side of plugs, or both? I have 89 supra and doing same, but covered in oil on both sides. The problem is oil plug washers??? How is it getting to both sides of plug and all over coils? thanks.
I have done mine and all you need to do is to remove all of the parts like you was going to change your plugs out and take a 14mm hex socket and remove the hex bolt put the gasket with the RTV on both sides of the gasket and place back in; be careful not to tighten it too much or you'll crack the gasket. Or you'll have to repeat the process. Also, make sure to clean out your spark plug galley from all the oil and replace your plugs with new ones and check your plug wires and replace and or clean off as needed.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
