Old 09-22-2009, 06:43 PM   #18
oregonjoe
oregonjoe's Avatar
Default Drivers Side Connections 3
Once the Intake is in place you can place the main wire harness on top and run the connections for the Starter, VAC switches, Transmission Switch, Knock Sensor, and EGR temp down through the runners.
ID:	2369 Click image for larger version
The connectors are color coded so it’s not too hard to match them up. You can reach under and attach the Knock sensor and VAC Can connection under the runners.
ID:	2371 Click image for larger version
ID:	2372 Click image for larger version
