09-06-2009, 01:12 PM
#1
AEM EMS
The 7M-GTE Block has oil nozzles at the bottom of each cylinder bore to aid cooling. You may find the 7M-GE block has provision for them but blanked off, in which case just transfer the nozzles from one engine to the other. I think it’s the same case with the turbo oil feed and return into the block, I think the 7M-GE has a blanking plate that can be removed, your need to check that out though. The pistons are defiantly different, not sure about the rods and crank.
