Old 09-04-2009, 03:40 PM   #1
robertsws
robertsws's Avatar
robertsws is on a distinguished road
Exclamation
OK, so I took out the CPS, spun the sprocket around one whole turn, until the hole lined up with the groove again, re-installed it and checked timing. I was now able to time it to spec. So timing is not an issue anymore. However I still have that steady repeating pinging that increases with RPM. Only now I'm not sure if it's really coming from my #5 cylinder. It certainly sounds louder and clearer over my #5 cylinder, however I can hear it on any metal suface of the engine, including the turbo. I'm going to re-check my valve clearances next.
1991 Supra - Turbo - 5spd
60-1 upgraded turbo
Lexus AFM
3" exhaust, 4" tip
SAFC 2
550cc injectors (2 sets, venom direct fit, RC engineering)
2.5" intercooler and piping
Aluminum radiator w/dual electric fans
ARP bolts w/MHG
Full-auto turbo timer
Fidanza Flywheel & Stage 2 Clutch
spark plugs and wires.
power steering pump
cold temp start switch
engine top end rebuilt
transmission opened up and inspected at a tranny shop when the flywheel and clutch installed last week.
robertsws is offline   Reply With Quote
