Old 08-12-2005, 05:23 PM   #1
daiagaru2
daiagaru2 is on a distinguished road
if you just have water in the engine from it leaking into the plug hole,then change the oil and rinse the engine of the water.if smoking still persists after letting it run a while,maybe you have a leaking valve seal, or bhg.yes a stuck thermostat will make your car over heat.
daiagaru2 is offline   Reply With Quote
