Old 05-21-2009, 08:04 AM   #1
86.5 7MGE
86.5 7MGE's Avatar
Talking
Originally Posted by Moy View Post
unless you have a turbo, don't bother with the header. no aftermarket header will bolt-on, there has to be modifications done to it so that itll fit. more money than its worth.
There is headers for the NA made by Monzda Pacesetter you have the choice of 4:2:1 has a choice between armor coating or hi temp blk or 4:1 only comes in hight temp blk and both are made out of mild steel which is not ideal for turbos since they run so hot it would warp them ; there is also aftermarket headers made specially for the turbos as well that is made from stainless steel which is way better for turbos and can hold up to the beating...
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
