Old 03-09-2009, 10:22 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by E-ROCK View Post
When the light blinks it is just a continous blink. And the blinks are the same length I waited to see if maybe it would stop after some time and it doesnt stop. Thanks for the input
Is there a way to check the resister for injectors
There is a procedure to test each and every component in your entire Supra ... and those procedures are all detailed in the TSRM (Toyota Supra Repair Manual). If you're going to be doing troubleshooting and mechanical/electrical work on your Supra, you absolutely need your own copy.
I'll do some digging to see if I can find anything about a continuous flashing.
Life begins at 30psi.
