Thread: Afm questions
Old 12-10-2008, 07:37 AM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Well I run the Lexus AFM/ 550cc injector mod and couldnt be happier. Only problem is that if your getting that code is, since you have to use the housing (the black electronic peice on top.) from the original Supra AFM, your gunna have to buy that too since that is most likely the problem currently.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
