Old 11-27-2008, 03:26 PM   #1
subarumastertech
subarumastertech is on a distinguished road
you could possible have a vacuum leak. Vacuum leaks are most noticable at idle. causing rough idle or no idle at all. see if you can hear a hissing noise. If you do try using brake clean to spray along mating surfaces that you disturbed. if you have a leak the eng. will idle up . but also be careful brake clean is flamable only use whats necasary
subarumastertech is offline   Reply With Quote
