Old 10-17-2008, 09:18 PM   #1
Bill UK
AEM EMS
Bill UK's Avatar
Originally Posted by supra101 View Post
I just had the motor rebuild.
I assume if the engine was rebuilt, then the engine was probably removed. Its not uncommon for the engine mounts to become damaged when removing the engine. Worthwhile checking the two side engine mounts and the rear one under the tranny are not loose or damaged.Are you running with the stock crankshaft pulley, the reason I ask is that if you change the pulley for one of those shinny bling ally ones there will be no counter balance on the end of the crankshaft.
