Old 10-10-2008, 11:30 PM   #10
Tateslikeink
Tateslikeink is on a distinguished road
Originally Posted by suprra_girl View Post
Had a similar problem, when throttling it would overheat but as soon as i backed off/decelerated it would cool down again, I was leaking between combustion chambers. Have you done a compression check?
Yea, the numbers were all over the place. From the 6th cylinder to the 1st everything was weird. 1st was 120 2nd.. i can't remember.. 3rd.. i can't remember, 3rd 145, 4th 155 6th 160. How would one go about fixing this issue if it was a leak between combustion chambers?? Because thats kind of how it is... Except, if i turn the car off, then start it again, its at normal temp.
Tateslikeink is offline   Reply With Quote
