Old 09-29-2008, 03:48 AM   #10
Grandavi
Grandavi's Avatar
Originally Posted by mrnickleye View Post
The little black lever on the door post is the seatbelt tensioner. It allows a slightly less tension on the seatbelt when you are wearing it, to allow you to move forward easier (like reaching into the glovebox).
More tension when door is open, to help retract the belt when you take it off. Isn't Toyota thoughtful ?
The should have spent MORE TIME getting the BHG problem solved.
By the way, after owning my supra for 6 years, and moderating this forum for about 3 yrs, I have determined that the headgaskets will go bad (leak again, even just a tiny bit) about every 3 yrs, or 20k miles.
I will do a thread on my findings soon, so look for it, I will sticky it in the general section.
So, is there any way to tell when the head gasket is leaking "slightly"? The head gasket in my car isnt a Toyota gasket, but it isnt a MHG either. Plus the bolts aren't ARP and I haven't checked yet to see what the torque is on them, but would hope that whoever rebuilt the engine torqued them correctly. I get to see them when I redo the top, but if putting a MHG (or alternative gasket as I dont really plan on putting in oversized injectors or a larger turbo) and ARP headbolts would solve the issue longer, I would go for it. I plan on keeping the car for about 10+ years so I do want to pamper it a bit.
