Old 09-25-2008, 10:18 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by sloth View Post
will the vvti gte head bolt onto ge block read in other thread gte head will.
is it worth the time as I will have to do the ignition setup there to etc??wanting 230rwkw, or just put the turbo onto the stock ge via aftermarket manifold my best option...
Which "turbo" are you referring to?
I believe the vvti gte head will bolt to the ge block, but I'm not 100% sure. Even if it does, one of the biggest problems is that you'll need to change out the complete wiring harness and ecu, and add in things like an ignitor in order for the gte head to work in a ge (non-turbo) Supra.
Life begins at 30psi.
