Thread: 87 Supra NA
Old 07-28-2005, 12:20 AM   #1
Intenseneal
Guest
Posts: n/a
If you decide on buying the NA and want a turbo I have a stock CT26 turbo manifold and turbo 440cc injectors for sale $80 for everything. As far as is the NA worth buying that is all up to you and what you are looking to get out of the car. The NA motor has a higher compression ratio and with the right tuning has the potental to make more power than the turbo motor dueto the higher compression ratio. But again tuning will be very important to keep the motor alive.
