Old 07-21-2008, 06:28 AM   #1
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
Thanks. I think it's OK now. It's my wife's car, and I think she managed to turn the key CCW. The car was locked when I tried it, but after I unlocked it the key opened the hatch.
Now I can see that while the inside cable is hooked up, it must have stretched a bit because it doesn't pull quite far enough to open the mechanism. I think I'll remove that inside center-rear panel and see if I can make it pull a bit more.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
