No Start Hot
Thanks for all of the help! The problem turned out to be a fault ignition switch. When the car heated up, the switch would fail, causing a loss of power to the efi main relay control side circut. This in effect cuased the fuel pump to shut down. By inserting a jumper wire, bypassing the efi main relay, the car started and ran find. From there, we were able to back track to the ignition switch.
