Thread: where to buy?
Old 03-13-2008, 03:53 PM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Thumbs up ARP Studs
i agree 100% ARP Studs are easy And Work wonderfully.. i had a 87 Supra, Blew a headgasket....a 88 supra, blew a head gasket, then i thought i found a nice running 89 turbo supra, well i was so happy to find it i only drove it for 15 min on the test drive, didn't even make it home and knew it had a blown head gasket...... so i put ARP's And Cometic MLS headgasket... torqued the studs to 90 FTP and havent worried about them since... Dave At Horsepowerfreaks.com knows his shit, and he gets it done, when building a supra make sure you stick with one person on your parts, you'll see the deals getting better and better.... good luck, do it right the first time, or you will be very sorry.
like what was posted before his
the number is 1 866 473 5600
.ext is 103.... dave
Supra_87_mk3 is offline   Reply With Quote
