Old 07-13-2005, 12:45 PM   #1
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
fuel cut is extremely violent and you will know when you hit it
it varies on your mods
generally stockish is about 12psi before you hit it
i hit mine at 9psi but thats due to the vastly increased flow than stock.... which won't be there long as i'm getting lots and lots of toys heh
i don't recommend getting a fuel cut defender... if you do... buy it.. install it... drive it (yes that means DRIVE not boost) to your dyno shop and make sure that the boost you turn it up to has enough fuel supply... once you have that done DO NOT alter your boost controller.... unless you would like to spend thousands in repairs
GL
Pics of my build.
Do a diagnostic first!
