It might also be that some messed with the setting on the box. Check underneath the drivers side dash in the footwell. Cant remember at the moment if its on the side next to the door or underneath the dash. I know of cases of some people that have kicked the box on accident and it actually moved the sensitivity up all the way to the highest setting. Check on that.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
