Old 01-23-2008, 06:26 PM   #2
Pretaco
Pretaco is on a distinguished road
Well in that case I have no idea.
j/k....
The one that doesn't move, can you hear the motor turning? Can you manually pop it up easily? If the motor is inop, check for power and ground at the motor, the motor also has position sensors to shut the power off when they get at the up and then down positions.
If you can pull it up easily and the motor is working, then the rod between the motor and the light has come off.
First thing is to check the fuses, then power and ground at the motors, and each rod is connected between the motor and the light. You can check that by removing the rubber cover on the top of the motor and manually turning the motor. If that works then the rod connection is good. They should also turn pretty easy. If they are hard to turn the motor might be seized or the light hinge is bent or something.
The retractor relay is under the dash on the drivers side, its green if I remember right.
'88 Supra Targa 5 speed w/ '90 7M-GTE
Currently Running Good
For Sale: Light blue body parts, Blue interior parts all from '90 supra targa turbo manual.
Also for sale: R154 trans, brake pedal, master cylinder, booster, abs actuator, sensors, abs ecu, driveshaft, 3.90 lsd rear end, radiator, wiring, speedo cable, 8 saw blade wheels, '88 ecu, relays, cruise control actuator (bad cable), empty fuel tank, etc....
Pretaco is offline   Reply With Quote
