Old 01-19-2008, 02:08 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by marmlr339 View Post
thanx. fuel injectors... i just assumed they would be needed. im quite new to all this stuff and what is the difference between rwhp and hp? sorry im used to kw. and i means 550hp or about 400kw. ...
RWhp is horsepower at the rear wheels...for example, the power directly measured on a chassis dyno. HP measured on an engine dyno is power at the crank...before driveline losses. With a manual transmission, driveline losses are about 15%. With an auto, losses can be anywhere from 20%-30%.
...would mucking around with the turbo timing, etc car tuning add extra power to the car? and is it possible to do it without a profesional or would that be recommended?...
Turbo timing alterations aren't necessary but you can raise the boost and get it to about 400rwhp (about 470hp at the crank, which is a great increase over 320hp) without changing the turbos! You can read more about 'bpu' here:
mkiv.com
...and here:
MKIV.Com Home of the MKIV Toyota Supra
...oh yea and what i've been looking at has around 60 - 100,000 km's (40,000 - 60,000 miles)...
Maintenance records and driving habits of former owner(s) is critical when looking at a Supra TT with some miles on it already. You'll want to have it professionally inspected by an objective, qualified, and above all experienced Supra mechanic before you purchase it.
...98 models i think are best.
Why do you think 98 models are best?
Life begins at 30psi.
