Old 01-17-2008, 04:04 PM   #2
t4yl0r10
t4yl0r10 is on a distinguished road
Well, ive checked the High Beam fuses. They are the normal clear plastic fuses, and they work just fine. Just my low or regular beam lights aren't working. There is a big fuse, different than the others, that says "HEAD" on the diagram. I'm wondering if thats it??? Sounds like a pretty easy trial and error run in any case. Thanks for the help!
One more question: Just had a bunch of work done to my Supra. New engine gasket kit, all new seals, timing belt, clutch, hoses, belts, water pump, tires, struts, and a few other minor things. Its running great, only its not starting as well as it did. Granted, its really cold here right now, but it was starting quickly before I had the work done, now i have to pump the gas, and give it about 6-7 tries to get it started.
Any idea what I can do to remedy this? I can't be wondering if my car will start on a daily basis, and this can't be good for the starter or the battery.
Any help would be great!
Thanks!
Taylor
1985 Toyota Supra 5MGE DOHC 2.8L 12v L6
t4yl0r10 is offline   Reply With Quote
