Thread: Slipping Clutch
Old 07-07-2005, 07:19 PM   #1
ddmcse
ddmcse's Avatar
the common thought is to replace the head gasket with a metal head gasket , torque the head down better than factory specs and you are all set . however let me tell you thats bullshit
the two surfaces need to be flat flat and smooth as glass . a guy will pull out the head and have it finished, bolt it back on and call it a day , but what about the block . the block most likely gets zero attention
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
