Thread: new intercooler
Old 11-18-2007, 07:17 PM   #3
west_side_supra
west_side_supra's Avatar
see the way i'm thinking of running my 3 inch pipes is from the TB go out straight then do a 90 around the tems, then straight through the bigger hole in front of the air filter then go down into the ic inlet, as for the turbo side, do a 180 or 2 90's go under the radiator then a little straight piece then another 90 then straight with another 90 going up into the turbo. i dont know if there is a way to go under the oil pan but that was another way i was thinkin of doing it. mmm as for the turbo question its a Gt46 : Compressor Wheel - .66 A/R, 48.9 trim Turbine Wheel - 1.05 A/R, 61.9 trim 4.25" inlet, 3.38" outlet T4 flange with V-band i never really got a name for the turbo, but thats what i had hunted down with all of those specs, and i know in the manual it says something like super hybrid, i'm curious how it will spool up
7MGTE - 500hp never dyno'd
fidenza cam gears
