Thread: accleration
Old 10-22-2007, 03:05 PM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
is it turbo? if so are you geting any boost? if not is the idle ok are there any vacuum leaks. if you dont know take a bottle of carb cleaner and spray it on the throttle body and other tubes if the idle goes up you found a leak.
another prob could be. did you take off the tps or move it at all?
Supra_87_mk3 is offline   Reply With Quote
