Old 09-24-2007, 11:28 PM   #1
kevo
kevo is on a distinguished road
Originally Posted by pwpanas
In a US-spec Supra, the oil light never stays on when you start it, unless your oil level is low. When I fill mine, I use six (US) quarts (=1.25 UK gallons, or 5.68L), which takes it right to the top of the full-line on the dipstick.
If your Supra was/is completely filled and it still makes the noise, unfortunately I don't have an easy fix to get rid of that noise. Best case, it's something as simple as the clicking of your injectors in your (cold) fuel system. Worst case it could be your oil pump, the early stages of rod knock, or both. Trying to diagnose something like this is extremely tricky over the internet.
Also, I do have a contact in the UK that I can forward you to if you need to find a shop that is experienced with Mkiv Supras.
Thank you PWPANAS,...For your reply....Looks like i need a new oil pump me thinks......
Thanks again....Kev.
kevo is offline   Reply With Quote
