Old 08-30-2007, 02:29 AM   #29
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by verbal
well I guess I was vague and I apologize. I understand the easiest way to make up the HP difference would be to increase boost that is obvious. But I was just generally inquiring about what caused the difference in hp, if it was just lower boost being used or the internals were causing the difference...
It seems you pretty much already know the answer, as you posted above: "...the ECU...replace the turbo's...increase injector size..."
The only thing you missed is the intake side cam (larger duration in the us-spec). Other than that, the internals are identical.
Life begins at 30psi.
